kelford V2-199-C cams
Hi Im fitting some kelford V2-199-C cams, engine is a 2.5, does anyone have any base clossed loop vvt figures for these cams? I have a feeling they will be nothing like the std figures for the sti7 cams, just something sensible to get me going.
Re: kelford V2-199-C cams
hi
setup your offsets when warm at right rpm and then tune the car to suit .
standard tuning tbh .
also if your unsure on drive target being right.
take the vvt soleniods out of equation by unplugging easy to get them right
Hi cheers Im fine with the latch points, it was the amount of advance I should target I wasnt sure about since these cams have way more duration than the std sti cams. I was just looking for a safe figure to get me running, the std cams are around 35 - 40 degress on my setup, Ive gone for 11 degrees with these and alls good.
