I was driving on the road and suddenly engine stopped. Crank sensor did not give signal anymore on starting after that.
Attachment is synch log at the end you will see final situation before engine stopped. Also there is cal-file. I have tested with another new crank sensor but no signal. I tested both crank sensors and they worked well. I also tested that all the wiring is correct and nothing is lose or broken.
Crank sensor send a signal to the ecu pin (measured) but still ecu does not notice any signal
  Is it possible that something is broken inside the ecu ?
Edit:
There is no cam signal also in synch log now.
-Mikko-
 ). Always close to rev limiter or right away on next gear.
