ballast resistors
ford racing
ballast resistors
hi iam going to be using low impedance injecters on an s8 and need to know how to work out what size ballast resistors to use.thanks in advance
Re: ballast resistors
http://uk.rs-online.com/web/p/panel-mou ... s/0160714/
If mounted on a heatsink (ie cool spreader plate) then 15w will probably also be fine.
Or maybe pick up some resistor packs from an OEM car.
Some Mitsu Evo's use them, Toyota MR2 turbo, old Honda Civics and perhaps others
I thought that S8 can control low impedance injectors without any extra resistors. The pinout pdf says 10A Open Collector output.
Yes it can. I've not found it to be 100% reliable, I described my experiences and advice on another thread.
