Hmmm couldn't see em. Was having issues I think the app with the menu out and not closing.
I'll do the old delete and renowned load and install.
Um as far as the other bit, uh pat, help!!! Lol
That bit went over my head. I'm up to clinic on Sat so can ask pat to check if that helps?
Syvecs Android App Chat - BETA Now Available!!!
Moderator: Wez
Re: Syvecs Android App Chat - BETA Now Available!!!
Slight update, removed the app from my phone and reinstalled and seems to have updated ok that time.
Can't see the oil temp/pressure though?
Hiya, I have checked and you are right, Oil temp / pressure is missing from that build, I am planning to push another build out and will make sure they are included along with a few others.Tidgy wrote:Slight update, removed the app from my phone and reinstalled and seems to have updated ok that time.
So had a chat with pat and we had a look at what's going on.
First thing there seems to be a glitch with the menu staying open, only way we found to close it was to reset the whole software so loosing all the settings.
Second thing was indeed the assignments were incorrect so that sorted out the readings, due to the menu issue they were lost straight away though so need to be reset again.
Any chance you can send me a screenshot of the menu staying open issue, thats a new one to me.
Glad you got the assignments sorted, obviously having to reset is not going to work though.
Can you also take a screenshot from the device information screen within the app, should be under settings.
should be attached.Wez wrote:Any chance you can send me a screenshot of the menu staying open issue, thats a new one to me.
- 2.png (415.15 KiB) Viewed 98306 times
- 1.png (421.09 KiB) Viewed 98303 times
- menu.png (552.86 KiB) Viewed 98295 times
other settings
- 4.png (418.32 KiB) Viewed 98298 times
- 3.png (417.66 KiB) Viewed 98304 times
Thanks.
I see it says live, do you get data if you enable the stream?
Data is coming through when the right setup is on there.
OK great, I am looking into ways that I can try and capture the crash you are experiencing.Tidgy wrote:Data is coming through when the right setup is on there.
Can you give me a little more detail on what happens or correct me if I understand it wrong.
Sounds like you load the app from a fresh install, configure your assignments, start the stream and assign gauges and this is working?
What happens between this and the crash?
Does killing the app off from running in the background and simply restarting not fix the issue, do you have to uninstall the app and reconfigure?
