Knock base will log as CYlXknockthresh
Logging rate shows at bottom of screen
Ignition retarding
Re: Ignition retarding
That isnt a low gain value at all.....of course not all sensors or engines are the same, so it's up to you to determine what is right for your setup.ScoobyDuck wrote:
I will raise those first 2 cells. As its so quiet (although that depends on gain i guess (curerntly set to 1.231))
I wonder if Syvecs are still doing the 'upgrade' (I thought it was free at one point? or was i asleep again).
thanks
Steve
I dont believe the upgrade is free, but it is available if you send the ecu in.
ScoobyDuck
Rate - F1 Help -didnt have that on ! Thanks!
I've tried CYLxKnockthresh and its not there for the S6 v1.74.2 using a new config, not my own. So i guess there is a bug there somewhere (or i need a new cfg file?)
ok to upgrade - i idnt think it would be free :p
thanks
Steve
thanks
Steve
- knocklist.png (10.4 KiB) Viewed 62013 times
send me your email.
ScoobyDuck
Thanks Stevie
Knockthreshold now on scfg, Areas at low knockbase raised slightly. More logging needed to see whats going on.
Also lowered the Hz of knock as that was wiping out my logging memory a bit.
Steve
Steve
