stevieturbo wrote: Tue Dec 24, 2019 10:53 am
So even at a maximum...there is almost some 20% discrepancy ?
I know at times I've maxed my sensors at the collectors as the ecu only seemed to go to 999 ? Or maybe that's just where it topped out on those brief occasions.
I've tried to keep it a lot lower since those happened, certainly the port runners always read lower
The below is a pretty homo test, different set up heights, different days, different gun (same model filled to max but not same), different fine wire probes! & the group probe test (across three) means had to balance the flame cone so middle gets the peak, the two on outer less. So lots of issues, but they were both adjusted to reach maximum temps.
Anyway you can see figure onboard S8 TC input v the ETI, both reading above 1300 deg C.
Needs a proper test which I will do tomorrow and put up, till then this will suffice.
~1333 deg C
~1357 deg C
