I keep having to log in on every visit despite being on a static IP address and cookies allowed.
Any way to solve?
						permanent log in not working
Re: permanent log in not working
May be they are trying to tell you something! PMSL!
I recognise you from the wr1oc....i am JP on there!
Allow me to switch from dyno/ecu mode into tech support
You should be able to remain logged in. I would delete all your cookies etc and try logging in again checking the 'remain logged in' box once more.
I shall meander off and check your settings just to be sure.
What browser are you using?
Charlie.
Charlie.
Firefox 3.0.3
Cheers Charlie
It's no biggie if you can't sort it but it is nice to look in every day to see the latest incarnations and installations for when I finally get mine in the car.
						Cheers Charlie
I'm experiencing the same problem after the domain name change. I guess phpBB tries to set cookies with the old name.
Should be fixed
All solaris-ecs traffic is HTTP 301 "Permanently Moved" over to syvecs.com, so cookies now set to syvecs.com. If you log in using syvecs.co.uk the board will still work but it may not remember your details... would therefore suggest using syvecs.com.
