Latest Base Map
Technical Help / Firmwares for the Porsche 997.1 / 9972 Awd Controllers
Locked
Latest Base Map
The latest Porsche 997 AWD Base map which matches the latest firmware can be found below in Attachments
AwdBase_997 1.15.SC
(38.8 KiB) Downloaded 3570 times
1.18
AwdBase_997 1.18.SC
(42.89 KiB) Downloaded 3770 times
1.21 Base Map
For use with 1.21 Firmware
AwdBase_997 1.21.SC
(46.26 KiB) Downloaded 3461 times
1.23 Base Maps
For use with 1.23 Firmwares
AwdBase_997 1.23.SC
(51.46 KiB) Downloaded 3586 times
AwdBase_997 1.23 X4.SC
(51.46 KiB) Downloaded 3437 times
1.24 Base Maps
For use with 1.24 Firmwares
AwdBase_997 1.24.SC
(55.83 KiB) Downloaded 3452 times
AwdBase_997 1.24 X4.SC
(55.78 KiB) Downloaded 3464 times
1.25
AwdBase_997 1.25 X4.SC
(61.05 KiB) Downloaded 3495 times
Re: Latest Base Map
For use with 1.27 Firmwares
AwdBase_997 1.27.SC
(66.84 KiB) Downloaded 1590 times
AwdBase_997 1.27 X4.SC
(66.87 KiB) Downloaded 1551 times
Re: Latest Base Map
For use with 1.28 Firmwares
AwdBase_997 1.28 X4.SC
(72.44 KiB) Downloaded 1240 times
Re: Latest Base Map
1.29 Base map
AwdBase_997 1.29 X4.SC
(72.89 KiB) Downloaded 1048 times
Locked
