Latest 50hz GPS Firmware
50Hz GPS and IMU Module
This thread is for tracking the firmware builds for the Syvecs 50Hz Gps Modules. When a new release is available it will be added to the end of this thread.
A manual on how to flash the latest firmware is here http://www.syvecs.com/downloads/Syvecs_Updater.pdf
1.2
Firmware 1.2 of the 50Hz GPS Module is attached below. This firmware will be loaded onto new sales from the 10/3/21 if you purchased before then we recommend updating.
Please use the Syvecs Updater program to load the ENC file. Guide here http://www.syvecs.com/downloads/Syvecs_Updater.pdf
ENSURE the GPS is sealed again if using in harsh environments with a silicon based sealant
The 1.2 Firmware fixes the following issues:
* Added Support for Bosch MM5 (see manual for Can Info - http://www.syvecs.com/downloads/Syvecs_ ... Module.pdf)
* Added Support for Motec M1 Series (see manual for Can Info - http://www.syvecs.com/downloads/Syvecs_ ... Module.pdf)
* Fixed Uart Boot Issue
* Faster Wakeup of Device on Canbus
SyvecsGPS_v1_2.zip
(16.18 KiB) Downloaded 5170 times
1.3
Firmware 1.3 of the 50Hz GPS Module is attached below. This firmware will be loaded onto new sales from the 18/11/21 if you purchased before then we recommend updating.
The 1.3 Firmware fixes the following issues:
* GPS Chip firmware error which would cause the unit to not boot correctly
SyvecsGPS_11_21.zip
(17.69 KiB) Downloaded 5046 times
1.4 Firmware
Firmware 1.4 of the 50Hz/100Hz GPS Module is attached below.
The 1.4 Firmware fixes the following issues:
* Added support for 100hz new hardware
* Signed issue fixed on heading
* Speed Jumping issue fixed when stationary at high altitudes
SyvecsGPS_50Hz&100Hz.zip
(17.91 KiB) Downloaded 5086 times
1.5 Firmware
Firmware 1.5 of the 50Hz/100Hz GPS Module is attached below.
The 1.5 Firmware fixes the following issues:
* BugFix for 100hz IMU Data being 90deg out with New IC
SyvecsGPS100hz Lat Long Fix.zip
(18.24 KiB) Downloaded 5039 times
1.6 Firmware
Firmware 1.6 of the 50Hz/100Hz GPS Module is attached below.
The 1.6 Firmware fixes the following issues:
* Improvements for signal decoding in areas where sat data is limited
SyvecsGPS.zip
(18.4 KiB) Downloaded 3024 times
Return to “Syvecs 50hz GPS / IMU Module”
