BOSCH LSU ADV configuration
taronsargsyan
Post by taronsargsyan »
Hi
ECU: S7 plus
planning to have BOSCH LSU ADV pre turbo installed on N54 for dual bank setup, same time I will keep two lambda on downpipe for different debugging/troubleshooting scenarios.
Need to know how the heating strategy is configured on this ecus. according to datasheets this lambda sensor have different heating strategy.
any input is appreciated
regards
taronsargsyan
Re: BOSCH LSU ADV configuration
I have checked the output functions and see there are some configs for lambda heating. However Im unable to see how I can implement something similar to what the ADV or 4.9 spec require. Both have dependency on time on startup and afterwards. Any ideas if this can be configued somehow using CM maps ?
regards
Alex Bable
Post by Alex Bable »
I was wondering how what your outcome was trying to get this sensor to work with syvecs? I am planning a build and with my configuration the ADV sensor seems like it would be the correct one for my application.
lilycollins9x
Post by lilycollins9x »
Alex Bable wrote: Sun May 12, 2024 1:19 am I was wondering how what your outcome was trying to get this sensor to work with syvecs? I am planning a build and with my configuration the ADV sensor seems like it would be the correct one for my application bitlife
I hope you obtain the results you want. I also think the ADV sensor is quite dependable and appropriate for high-precision applications like yours!
