Latest Base Map
The Syvecs OEX (Oe Ecu eXpander) is a powerful expander module enabling advanced after market features on existing engine management systems via CAN/CANFD communication system . By utilising the well proven Syvecs X20 hardware a version of software has been created to provide our Syvecs market leading features into the Oe Ecu eXpander package. This provides the best solution for clients needs that require to expand the capability’s of an original ecu control module or to integrate with another engine control unit (Master)
Locked
Ryan.g
Syvecs Staff - Caretaker
Latest Base Map
Post by Ryan.g »
The Syvecs OEX 1.107 Base map is the initial product release firmware, as more features and strategies are added they will be found in this OEX Section
1.107 Code - Base Map Attached
OEX 1.107.SC
(146.25 KiB) Downloaded 609 times
Ryan.g
Re: Latest Base Map
Post by Ryan.g »
The Syvecs OEX 1.114 Base map is the latest product release firmware, as more features and strategies are added they will be found in this OEX Section
1.114 Code - Base Map Attached
OEX 1.114.SC
(149.8 KiB) Downloaded 308 times
Locked
Return to “OEX - Oem Ecu eXpander”
