Electronic Steering
Re: Electronic Steering
It would not be normal to have the 12v side of the relay permanent in order or any trigger to energise a relay with the ignition turned off.
I have heard quite a few people report S7 outputs causing relays to turn on when the ECU is off. Whilst Stevie is right - it is best not to have a relay powered by a permanent live - I personally do not think it right that an ECU output can sink enough current to turn on a relay when the output is off. Other ECUs don't so it could be an S7 design shortcoming
I don't have one here to test, so can't say.
But it would be unusual, yes.
I doi...but on holiday...I'll make a note to investigate this when i get backstevieturbo wrote: Wed Mar 29, 2023 6:35 pm I don't have one here to test, so can't say.
				amdisthebest
Not all the outputs go to ground when powered off. The H-bridge outputs do but the fuel outputs don't in my experience (S7+).
