Page 2 of 3
				Re: Engine Cut for cartek XR
				Posted: Mon Apr 08, 2024 2:54 pm
				And input is configured as 5v ?
Datalog the raw input to see what it's doing/seeing.
All works fine on a couple of S8's I've done.
Ask on the Facebook group, more traffic there.
				Posted: Mon Apr 08, 2024 2:59 pm
				by tricky1024
				where do you configure the input as 5v?
				Posted: Mon Apr 08, 2024 3:13 pm
				Actually, you won't need to as you've used a 0-5 volt input that is not configurable.
On S8, it works easy. Unless there's something the S7 not happy with.
But log the raw input to see what is seeing.
				Posted: Mon Apr 08, 2024 3:51 pm
				by tricky1024
				i will log and see what is happening, just for future reference, how would you configure the inputs and outputs?, for example the H Bridges?
				Posted: Mon Apr 08, 2024 4:33 pm
				Posted: Mon Apr 08, 2024 5:44 pm
				by tricky1024
				ok, traced the an04 input, get a nice 4.9v showing on the input, when the car is then started it goes from 4.9v to 1.22v then jumps up and down repeatedly. i think im going to disconnect the input and monitor with a scope and see if the input is the issue.
				Posted: Mon Apr 08, 2024 5:45 pm
				Odd.
Try and test as you say, measuring the Cartek white wire when not connected to the ecu.
I assume the blue button on the Cartek isn't flashing any faults ?
				Posted: Mon Apr 08, 2024 6:47 pm
				by tricky1024
				nice solid LED on the internal button, very odd indeed.
				Posted: Mon Apr 08, 2024 10:20 pm
				Just checked again, was in work and couldn't earlier.
C13 is a configurable input. So do you have the pullup off ? so it is just a regular 0-5v input
upload your cal
				Posted: Tue Apr 09, 2024 8:57 am
				by tricky1024
				pull up is off, ill PM you the cal so you can check it over
