Page 2 of 6
				Re: Syvecs iPhone / iPad App Chat
				Posted: Mon Jan 20, 2014 8:52 pm
				by Steve
				Hi Wez,
Not sure if it's just me but I have noticed that when trying to put in custom CAL names/labels ' CAL 1' can't be altered as it is underneath the heading so can't be clicked on.
This is the same on iPhone 4S, iphone 5s and iPad.
				Posted: Thu Jan 23, 2014 12:34 pm
				by Wez
				Steve wrote:Hi Wez,
Hello Steve,
I am assuming your on iOS7, this is a nice new feature from the gui changes Apple made, it will be fixed in the next release
Wes
				Posted: Thu Jan 23, 2014 3:33 pm
				by Steve
				Yes iOS7
As long as you know
				Posted: Fri Dec 05, 2014 9:32 am
				by Motoka
				secure wrote:I can't rotate the screen on IPAD mini? No landscape mode on ipad mini?
I am also having the same problem on iPad mini using iOS 8.1.1 which is the latest version and also 2.1.4 of the syvecs ap. any ideas.
Rather annoying as I have the iPad dash mounted in landscape position.
				Posted: Mon Dec 15, 2014 10:49 am
				by Wez
				Motoka wrote:secure wrote:I can't rotate the screen on IPAD mini? No landscape mode on ipad mini?
I am working on a FIX for this, Apple in their wisdom treat the rotation on the iPad mini different to iPhone which it works fine on.
The plan is to have a dash lock function in settings so you lock out rotation and have it only work in lanscape mode for fixed installs.
				Posted: Tue Dec 16, 2014 8:13 am
				by Motoka
				awesome thanks Wez
				Posted: Sat Mar 21, 2015 6:13 pm
				by Motoka
				Hi Wez
thanks for the latest version
 Great work. The only issue I have noticed that when I rev over 5000 rpm the rpm field and gear sift lights freeze for around 20 seconds?
				Posted: Sat Mar 21, 2015 10:03 pm
				by Wez
				Motoka wrote:Hi Wez
Thanks.
Thats a new one for me, I will check out the code tomorrow.
Does the issue have every time you go over 5000rpm and does it move if you change the shiftlight settings?
				Posted: Mon Apr 13, 2015 8:37 pm
				by Motoka
				it's every time I go over 5000 rpm thanks and yes it seems to be dependent on the gear shift settings
				Posted: Tue Apr 14, 2015 9:28 am
				by Wez
				Motoka wrote:it's every time I go over 5000 rpm thanks and yes it seems to be dependent on the gear shift settings
I am looking at the code now, are you using the custom cam stream or default stack stream?
Does it behave the same on multiple devices?
