bought knock sensor and wide band from JTI
so finished off my COP set up , chuffed with that ,
Untitled by Jack Strathdee, on FlickrAlso finished my wireing loom for the aux sensors - Knock , water and oil temps , oil and fuel pressure
My mapper and the person that was going to install the ECU has had a slight side shift with the company he works for , basically a name change , but its a building change ect as well, going to prob be a month before they will be able to see the car , i could prob make that work but after the wireing loom im on a bit of a high with it all!
So iv decided i might give wiring up the ECU my self , but this might be out my depth ! will see i guess!
I have a few questions , below is a ECU pin out of the ford ECU
focus ecu2 by Jack Strathdee, on FlickrI have a few questions , as im not 100% sure on how it all works with a few things , and what looks alien to me might well make scene to someone else
First thing i think is simple but thought id ask any way , the alternator on the focus is a smart charge item , im assuming the controls are pin 59/72 , removing this should just turn the alternator into a normal non smart charge yeh ?
second is the started relay (K4 pin 27) , so i just run this to an after market switch or the trigger from the ignition barrel ?
next , is syvecs pin 6 which is classed as Trigger ground - crank and cam sensor grounds , i take it i can share the grounds for both cam and crank sensor ? (pins 76 and 22 on the ford ECU)
and this one is the one that i could be over thinking , Fuel pump , pin 54 on ford ECU , is that what turns the fuel pump on ? i cant make up my mind if its a switched earth or not ?
below is the pin outs for the syvecs with me cross ref the ford ecu pins at the left side numbers
s6 pins1 edit by Jack Strathdee, on Flickr
s6 pins2 edit by Jack Strathdee, on Flickrim not 100% sure if i have the pins right for the throttle pos sensor ( B147) and the MAP sensor (B105) are they sharing pin 90 as a ground? and using 89 and 63 retrospectively for there out puts?
and last of all knock sensors , green circle is where ford fit there knock sensors to USA cars , we in the uk sadly dint get this , so that hole and thread is just a blank
Untitled by Jack Strathdee, on Flickrso im probably sounding like an idiot (spelling and grammar aside) , but im keen to give anything a bash as long as i know im not going to cause damage!
