Page 2 of 2
				Re: What do you think of these Bosch 1000cc High Imp Injectors
				Posted: Wed May 13, 2009 12:34 am
				by dynamix
				Just fitted these in mine today and they are good but dont flow quite what they suggest they do unless you up the pressure to them.  This would be why the differential pressure is high - they seem to need high pressure.
				Posted: Wed May 13, 2009 11:15 am
				by Sam@TDi
				Fair enough, it's just with 9bar (130psi) differential we're off the chart for predicted lag times
				Posted: Fri May 15, 2009 11:20 am
				by pavlo
				Sam,
I settling on 9bar OVERALL max pressure at the pump, we run 6.5 bar differential pressure.
I am just about maxing them out and an 800cc 5th injector running at the same pressure. It is making quite a lot of power.
				Posted: Fri May 15, 2009 12:28 pm
				by Sam@TDi
				Ah that makes more sense
