EGT probes
Re: EGT probes
And another one, a 'mild' street car set up with ~1870+hp on chassis dyno.
All other probes thrown in bin as these (customers words) are only ones worth using cause they actually respond in time, show what is happening, and to date not a single one needing to be replaced.
Any small setting difference is immediately reported, as are ignition miss fires, stop guessing, go donmega!
Re: EGT probes
STREET CAR
fact v fiction, cause no one races on a dyno !
when you really need probes that will do what no others can, there is only one, the donmega !
don probes track yo!.jpeg (82.48 KiB) Viewed 143529 times
dyno v track donmega.jpg (940.75 KiB) Viewed 143529 times
Re: EGT probes
REAL STREET CAR
Full length exhaust, no homo side pipes or cut outs
Power in reality matches dyno claims,, no fake fuel flow model 'guessed' numbers
Durability and accurate engine settings only offered by, tried, tested, & proven donmega probes
*GET ON IT !*
4.5 inch cunts.jpeg (246.11 KiB) Viewed 143521 times
FT PRO 1.jpg (48.77 KiB) Viewed 143521 times
Re: EGT probes
What is it ? a Supra or something ? What box ?
7's are flying
Re: EGT probes
stevieturbo wrote: Wed May 03, 2023 6:09 pm What is it ? a Supra or something ? What box ?
7's are flying
That track run had powerglide
Also ran with a K&N air filter ! and full length exhaust, no NOS used over the 400m either unlike others ;-)
was at low boost 60psi ~1600hubhp
donmega RX7.jpg (632.43 KiB) Viewed 143497 times
Re: EGT probes
Today and another more serious 'race car' with about double the power! swapping over to the donmega probes, when you really want to know what is going on then these are the FINAL SOLUTION
FINAL SOLUTION 5.jpeg (239.18 KiB) Viewed 143486 times
FINAL SOLUTION DONMEGA 3.jpeg (132.33 KiB) Viewed 143486 times
Re: EGT probes
Couple more race cars seeing the light ................ donmega probes for all !
FINAL SOLUTION 6.jpeg (159.67 KiB) Viewed 143477 times
FINAL SOLUTION DONMEGA 1.jpeg (149.43 KiB) Viewed 143477 times
Re: EGT probes
An update,
This car running *DONMEGA EGT PROBES* ran 7.17 seconds @ 202+mph yesterday
If you want to run fast consistent and reliably making each cylinder contribute its best on methanol fuels then you should be using a probe that will let you see what is happening ............
https://www.facebook.com/dragimportmedi ... 252899548/
RICE RACING wrote: Wed May 03, 2023 5:59 am REAL STREET CAR
*GET ON IT !*
Re: EGT probes
https://youtu.be/I33IeZF5ovo
^ Here is video of the pass for those who get hard watching others perform
RICE RACING wrote: Fri Jun 23, 2023 9:10 pm An update,
Re: EGT probes
Have a few more examples to share for the benefit of all following here, some will be more general in nature being applicable to a larger percentage of users, then others for the elite but all of them regardless remove one thing BLAME GAME !
Try to put it in a format that is understandable (if you are here then you are already one step ahead of most TBF) but should get people more access to what is otherwise closely guarded information that you just don't get on a pay to play education platform or A typical sponsored GagTube rantings :lol:
NOT FLINSTONES PEDAL CAR.jpeg (61.74 KiB) Viewed 135634 times
