Re: ecu issues
Posted: Sun Nov 25, 2018 5:52 am
				The forum members could help you much more if you posted up logs from your ECU, logs would provide a hundred times more information than a video.
I have seen issues with the comms wiring to the ECU, the wires are very thin and not as easy to terminate, so worthy of a check.
The only other issue I have experienced is that the lifenet server on my laptop appears a bit flaky when the laptop starts to go to sleep, there is a post on this Forum from Pat that talks about it. Sometimes when the laptop is brought out of sleep mode the comms spring back to life, sometimes I have to re-boot. However, this may be because my laptop ( DEll XPS 15) has an external Ethernet adapter.
When the lifenet server issue is present, all the characters on my screen go red, not just the ones at the bottom of the screen.
I can also see that the errors flag is flashing on your video, what errors are present when you go to view?
Stevieturbo is very experienced and is also very helpful, suggest you follow his advice.
