Page 3 of 4
				Re: Rotary switches for calibration changes, type question
				Posted: Sat Dec 10, 2011 9:36 pm
				by jalai
				What is a pullup resistance with this diode "chain"? -> I try understant how this work
And what is the type of diodes?
				Posted: Sat Dec 10, 2011 9:41 pm
				by TimH
				IN4148 diodes, and I would think something like a 10k pullup, but I don't know for sure.
				Posted: Fri Dec 16, 2011 10:56 pm
				by jalai
				It can't be work with 10k pullup.
I try 330ohm pullup to 5V and this is not good (with 6x 1N4148).
Syvecs people wakeup!   What is this diode circuit and it's pullup?
And... can You tell what is goin wrong with resistors?
				Posted: Fri Dec 16, 2011 11:03 pm
				by TimH
				6xIN4148 diodes would be a 6*.65=3.9V drop (approx). 1.1V across 330R would be about 3mA, so, yes, that would work fine.
A 10k would be 0.1mA which would also work.
So, what didn't work in your test?
And, sorry for the dumb question, but you did connect the diodes the right way round I presume?
				Posted: Sat Dec 17, 2011 5:10 pm
				by Jasper K
				Tim,
I think it's better to use diodes instead of resistors for the simple fact that the body drop on a diode is ALWAYS 0.6~0.7V provided the voltage of the source, in this case a pull-up 5V source, is sufficient to drive all the diodes into conduction.
If you would use resistors then the voltage drop on the resistors would depend on the voltage coming from the pull-up 5V source which would depend on the amount of current that is drawn. It's just a lot more complicated to get to proper resistor values when more or lesser cal. positions are used. To me it just doesn't make any sense to use resistors. You do not have these problems with diodes as the voltage drop is FIXED and almost doesn't vary with the current drawn out of the 5V supply.
People saying you cannot make a 10 pos. CAL-switch with diodes on a 5V powersupply are both right and wrong
When using normal Silicon diodes with a voltage drop of roughly 0.6~0.7V it is indeed not possible.
However there are such things as Germanium diodes which have a voltage drop of 0.3V as well as there are Schottky diodes with a 0.25V ~ 0.35V Voltage drop depending on the selected model. Therefor it is certainly no problem to do so.
Jasper Kopinga
CS Racing
Taiwan.
				Posted: Sat Dec 17, 2011 5:16 pm
				by Jasper K
				jalai wrote:It can't be work with 10k pullup.
Jalai,
You shouldn't add an external pull-up. You should use the Resistive Inputs on the Syvecs preferably (AR1~AR4) which have an INTERNAL pull-up. Then you connect the Rotary switch to this input. The way the rotary switch works is that every time you switch to a higher position it will ADD one more diode in series increasing it's output voltage by the voltage drop on the diode itself.
Jasper.
				Posted: Sat Dec 17, 2011 8:31 pm
				by Benkku
				Jasper K wrote:I think it's better to use diodes instead of resistors for the simple fact that the body drop on a diode is ALWAYS 0.6~0.7V provided the voltage of the source, in this case a pull-up 5V source, is sufficient to drive all the diodes into conduction.
I don't agree. Diodes has significant voltage drop vs. temperature slope. Source voltage do not drift nor change much. So resistor network is more accurate, than any diode.
				Posted: Sat Dec 17, 2011 9:06 pm
				by Chris Wilson
				Whilst this battle rages I am happily twiddling my RS Components rotary switch with Ebay resistors and all is well with the world. I really had no idea my initial post would turn into this technofest marathon
				Posted: Thu Dec 22, 2011 10:14 pm
				by jalai
				And more...
I do a small test today.
5, 6 or 7 1N4148 and 2,2k pullup resistor to 5V (I don't know what is correct pull up?).
Temp__5D____6D___7D
-20C__3,42V__4,00__4,49
20C___3,07___3,59__4,07
50C___2,79___3,27__3,72
Results in the
With Schottky this "problem" is bigger, because temperature coefficient is about same, but voltage step is much smaller.
				Posted: Thu Dec 22, 2011 10:20 pm
				by TimH
				For me, that's the nail in the coffin for diodes. I spoke with Pat the other day and I'm pretty sure he said the pullup was 3k3, by the way.
The only argument for using diodes is if the voltage at the top of the chain is unknown. So for a universal selector switch there is a case for diodes but where the voltage is known (as it is for the Syvecs) I really cannot come up with an argument in favour of diodes.
FYI Toucan has a voltage output to drive the Syvecs input so won't suffer this problem
