Page 6 of 8
				Re: Syvecs Android App Chat - BETA Now Available!!!
				Posted: Mon Feb 22, 2016 10:35 pm
				by Tidgy
				Hmmm couldn't see em. Was having issues I think the app with the menu out and not closing.
I'll do the old delete and renowned load and install.
Um as far as the other bit, uh pat, help!!! Lol
That bit went over my head. I'm up to clinic on Sat so can ask pat to check if that helps?
				Posted: Tue Feb 23, 2016 7:05 am
				by Tidgy
				Slight update, removed the app from my phone and reinstalled and seems to have updated ok that time.
Can't see the oil temp/pressure though?
				Posted: Thu Feb 25, 2016 11:07 am
				by Wez
				Tidgy wrote:Slight update, removed the app from my phone and reinstalled and seems to have updated ok that time.
Hiya, I have checked and you are right, Oil temp / pressure is missing from that build, I am planning to push another build out and will make sure they are included along with a few others.
				Posted: Sat Feb 27, 2016 6:59 pm
				by Tidgy
				So had a chat with pat and we had a look at what's going on.
First thing there seems to be a glitch with the menu staying open, only way we found to close it was to reset the whole software so loosing all the settings.
Second thing was indeed the assignments were incorrect so that sorted out the readings, due to the menu issue they were lost straight away though so need to be reset again.
				Posted: Sat Mar 05, 2016 8:43 am
				by Wez
				Any chance you can send me a screenshot of the menu staying open issue, thats a new one to me.
Glad you got the assignments sorted, obviously having to reset is not going to work though.
Can you also take a screenshot from the device information screen within the app, should be under settings.
				Posted: Sat Mar 05, 2016 3:54 pm
				by Tidgy
				Wez wrote:Any chance you can send me a screenshot of the menu staying open issue, thats a new one to me.
should be attached.
				Posted: Sat Mar 05, 2016 3:55 pm
				by Tidgy
				other settings
				Posted: Mon Mar 07, 2016 2:09 pm
				by Wez
				Thanks.
I see it says live, do you get data if you enable the stream?
				Posted: Mon Mar 07, 2016 3:52 pm
				by Tidgy
				Data is coming through when the right setup is on there.
				Posted: Mon Mar 07, 2016 4:09 pm
				by Wez
				Tidgy wrote:Data is coming through when the right setup is on there.
OK great, I am looking into ways that I can try and capture the crash you are experiencing.
Can you give me a little more detail on what happens or correct me if I understand it wrong.
Sounds like you load the app from a fresh install, configure your assignments, start the stream and assign gauges and this is working?
What happens between this and the crash?
Does killing the app off from running in the background and simply restarting not fix the issue, do you have to uninstall the app and reconfigure?
