S6 PnP MY00 - Base Map Issue V1.50 ?
Chartreux
Post by Chartreux »
Probably a dumb question, but I can't find answer by myself :oops:
I've loaded the base map V1.50 for my GC8 MY00 EUDM. I try it on the fully stock engine
The fuel pump prime when ignition is "on", but I didn't start engine due to the warning below.
I've checked the PIN Assignment, and it seems correct, the sensor configuration seems Ok also. The ECU firmware is the one from August 11th 2017.
Sorry to ask, but I try to run the Syvecs on my stock engine before starting with the new one. Thanks
Subaru MY99-00 EUDM
Lateral performance FMIC
Twinscroll header and uppipe
ID 1000cc inj
SYVECS S6GP PnP + Cal switch
Re: S6 PnP MY00 - Base Map Issue V1.50 ?
Do you have an air temperature sensor fitted and plugged in ?
Chartreux
Post by Chartreux »
I feel so....................................... stupid :oops: :oops: :oops: :oops:
You're right, I have no temp sensor fitted because it's OEM engine. Thanks man, I want to hide myself in a mouse hole :arrow: :arrow:
Subaru MY99-00 EUDM
ID 1000cc inj
Chartreux wrote:I feel so....................................... stupid :oops: :oops: :oops: :oops:
Just disable it in the I/O for now, or install one.
