Injector setup
torana
Injector setup
Post by torana »
When setting up new injectors would you adjust the following:
Prim. Injector Opening time - as per manufacturers specs
Global Multiplier
Re: Injector setup
torana wrote:When setting up new injectors would you adjust the following:
Global Multiplier
You would need to input any opening time data ( or dead time data as some might call it ) which yes the manufacturer should supply relating to pressure etc you will be using.
Global is simply a multiplier to increase or decrease fueling quickly. You could use this to make quick/large changes to fueling so you have an idea of what changes to make to the main fuel tables. Or you could just leave the global at whatever value you end up.
torana
Re: Injector setup
Post by torana »
Thanks,
Good I am doing it the correct way.
Just dialing in some 1650cc injectors on a 4 cylinder on 98 unleaded, and they were not being to nice but got them sorted now.
