gearCutState values
Posted: Fri Feb 01, 2019 2:43 pm
by amdisthebest
Hello all,
Can someone help me clear up what the following gearCutState values mean?
Masked
Clearing
My clearing state occurs for a longer time than I'd like (about 410ms) which is causing a delay in returning engTrqEstOutputTrans back to it's normal state which is causing my DCT to have clutch slip briefly between shifts.
During the clearing state, engTrqEstOutputTrans slowly ramps back up. Just after gearCutState returns to idle, trqOutput returns to full which gives the clutches full pressure.
I can’t find anything within the gearCut module that resembles masked or clearing. I actually can’t seem to find anything in the entire cal.
Any info on this would be awesome. I assume it might be something to do with the torque module instead.
Thank you in advance,
Nick
Re: gearCutState values
Posted: Fri Feb 01, 2019 4:26 pm
Masked is simply the delay from a gear cut action, where it will ignore any further requests because the current action is not yet complete. Perhaps more applicable to manual or sequential type boxes, than a fully automated DCT but I'm sure it still has a place. Time delay to be decided for each user.
To avoid multiple attempts of the same request type of thing that might have been an accident or something, say hitting lever too hard, or holding the lever on etc.
Clearing is I guess it just reverting back to a normal state after any controlling actions have expired.
Posted: Fri Feb 01, 2019 4:53 pm
by amdisthebest
Thank you for your response. I need to figure out how to shorten the clearing time because during that time trqOutput to the trans is ramped back in too slow.
Here's a screenshot if it's helpful at all:
- Annotation 2019-02-01 085008.jpg (201.22 KiB) Viewed 35734 times
Posted: Fri Feb 01, 2019 9:09 pm
I think I would be more curious as to why there is still a gear cut request active, when you're indicating what should be the power coming back on.
Posted: Fri Feb 01, 2019 11:36 pm
by amdisthebest
Upon further review, it's looking like there might be something wrong/flaky with the gearCut/blip request. I have a log earlier showing a gearCut request during a pull in 2nd gear.
- gearCutIssues.jpg (100.82 KiB) Viewed 35716 times
Posted: Sat Feb 02, 2019 8:11 am
by Ryan.g
The gear cut request is a flag that comes from a Message on the TCM (Trans control Module) with DCT plug and play kit for when Torque Reduction request is Active. If the TCM is wanting to reduce the Torque this will come active and the Engtrqlim will drop also which is the parameter from the TCM to telling the torque control on the Syvecs what amount of torque the tcm wants.
The Clearing state is when the gearcut time has gone past the amount set in Scal but request is still active.
The EngtrqOutput ramps in slowly as the syvecs is doing as the TCM wants based on the Engtrqlim. You need to either pull more torque to get the TCM happy and see no clutch slip or your cluch is not man enough for the actual Engine Torque you have.
If you are making more actual engine torque then what the OEM TCM was designed to see then you need to modify the torque reduction amounts or have custom tables to pull more to keep it happy.
Posted: Mon Aug 24, 2020 11:25 pm
by nmerdan
I'm looking at a somewhat similar thing, but my issue is that my engTrqEstOutput is 358Nm and I get a reduction from the TCM to 392Nm (engTrqLim). At that point the trqFuelSev jumps to 21.5% with a GEAR CUT as a source (there is no gear shift happening). So the torque is already lower than what the TCM is asking for, but the ECU still cuts fuel. This lasts about 100ms (need to increase my logging freq) and after that the engTrqEstOutputTrans continues to rise to the 392Nm value and after it reaches it, the ign retard is applied to maintain that torque as expected.
If I increase the fuel consumption scaling (using the alternate torque estimation), then this doesn't happen, but rather the engTrqLim comes in a lot sooner (as expected, due to us reporting higher torque to the trans), but is dealt with purely using ignition retard. This is a S7 PNP kit for the 2012 TTRS, and increasing fuel consumption scaling negatively affects shifting.
- syvecs_log.png (58.19 KiB) Viewed 33305 times
Posted: Thu Aug 27, 2020 10:56 pm
by nmerdan
OK, I figured this is happening due to Fuel Cut defined in the "Gear Cut -> Open Loop ... -> Fuel Cut Severity" section of the calibration. As far as I understand, this is to be used with sequential gearboxes, does it also apply to DCTs? Can I simply disable Gear Cut for all gears and let the Torque Estimation and Limitation part of the map take care of torque reductions based on TCM signals?
Posted: Mon Feb 01, 2021 6:46 am
by Westillo
nick, did you figure this out? could it be the clutch is actually slipping? I have the same issue which goes away when I lower shift rpm point. as I increase shift rpm the clearing state takes along time and shift time increase, this issue increases with rpm with me.
