Latest Base Map
Technical Help / Firmwares for the Infiniti Q60 Awd Controllers
Locked
Latest Base Map
The latest Infiniti AWD Base map which matches the latest firmware can be found below in Attachments
Please note this is only a base file for the device and we recommend you speak with your dealer about calibrating the unit based on the car setup.
AwdBase_QX60 1.15.SC
(38.8 KiB) Downloaded 5109 times
1.18
1.18 Base map, must be used with 1.18 Firmware
AwdBase_QX60 1.18.SC
(42.89 KiB) Downloaded 5504 times
1.21 Base Map
For use with 1.21 Firmware
AwdBase_QX60 1.21.SC
(46.26 KiB) Downloaded 5343 times
1.23 Base Maps
For use with 1.23 Firmwares
AwdBase_QX60 1.23 X4.SC
(51.46 KiB) Downloaded 5268 times
AwdBase_QX60 1.23.SC
(51.46 KiB) Downloaded 4943 times
1.24 Base Maps
For use with 1.24 Firmwares
AwdBase_QX60 1.24 X4.SC
(55.78 KiB) Downloaded 5421 times
AwdBase_QX60 1.24.SC
(55.83 KiB) Downloaded 4874 times
1.25
For use with 1.25 firmware on X4AWD Units
AwdBase_QX60 1.25 X4.SC
(61.05 KiB) Downloaded 5059 times
Re: Latest Base Map
For use with 1.27 Firmwares
AwdBase_QX60 1.27 X4.SC
(66.87 KiB) Downloaded 3137 times
AwdBase_QX60 1.27.SC
(66.84 KiB) Downloaded 3019 times
Re: Latest Base Map
For use with 1.28 Firmware
AwdBase_QX60 1.28 X4.SC
(72.44 KiB) Downloaded 2839 times
Re: Latest Base Map
1.29 base map
AwdBase_QX60 1.29 X4.SC
(72.89 KiB) Downloaded 2849 times
Locked
