The latest Porsche 997 AWD Base map which matches the latest firmware can be found below in Attachments
Please note this is only a base file for the device and we recommend you speak with your dealer about calibrating the unit based on the car setup.
Latest Base Map
Latest Base Map
- AwdBase_997 1.15.SC
- (38.8 KiB) Downloaded 5182 times
1.18
1.18 Base map, must be used with 1.18 Firmware
- AwdBase_997 1.18.SC
- (42.89 KiB) Downloaded 5504 times
1.21 Base Map
For use with 1.21 Firmware
- AwdBase_997 1.21.SC
- (46.26 KiB) Downloaded 5111 times
1.23 Base Maps
For use with 1.23 Firmwares
- AwdBase_997 1.23.SC
- (51.46 KiB) Downloaded 5353 times
- AwdBase_997 1.23 X4.SC
- (51.46 KiB) Downloaded 5143 times
1.24 Base Maps
For use with 1.24 Firmwares
- AwdBase_997 1.24.SC
- (55.83 KiB) Downloaded 5190 times
- AwdBase_997 1.24 X4.SC
- (55.78 KiB) Downloaded 5198 times
1.25
For use with 1.25 firmware on X4AWD Units
- AwdBase_997 1.25 X4.SC
- (61.05 KiB) Downloaded 5269 times
Re: Latest Base Map
For use with 1.27 Firmwares
- AwdBase_997 1.27.SC
- (66.84 KiB) Downloaded 3265 times
- AwdBase_997 1.27 X4.SC
- (66.87 KiB) Downloaded 3238 times
Re: Latest Base Map
For use with 1.28 Firmwares
- AwdBase_997 1.28 X4.SC
- (72.44 KiB) Downloaded 2915 times
Re: Latest Base Map
1.29 Base map
- AwdBase_997 1.29 X4.SC
- (72.89 KiB) Downloaded 2773 times
