Latest Firmware Releases
Posted: Sat Dec 04, 2021 11:21 am
by Ryan.g
Changes since 1.18
V1.19 Output Testing added
Firmware Version 1.21 - www.syvecs.com/downloads/AWD_Yaris_1-21-1.enc
1.23 Firmware - X4
Posted: Wed Jul 13, 2022 1:32 pm
by Ryan.g
Changes since 1.21:
OLD BOARD - Firmware Version 1.23 - www.syvecs.com/downloads/AWD_Yaris_1-23-1.enc
NEW BOARD - Firmware Version 1.23 - www.syvecs.com/downloads/X4AWD_Yaris_1-23-1.enc
1.23.3
Posted: Thu Aug 11, 2022 9:12 am
by Ryan.g
Changes since 1.23.1:
OLD BOARD - Firmware Version 1.23.3 - www.syvecs.com/downloads/AWD_Yaris_1-23-3.enc
NEW BOARD - Firmware Version 1.23.3 - www.syvecs.com/downloads/X4AWD_Yaris_1-23-3.enc
1.24
Posted: Fri Nov 25, 2022 12:05 pm
by Ryan.g
Changes since 1.23.3:
OLD BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/AWD_Yaris_1-24-4.enc
NEW BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/X4AWD_Yaris_1-24-4.enc
1.25
Posted: Fri Apr 07, 2023 6:59 pm
by Ryan.g
Changes since 1.24.4:
OLD BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/AWD_Yaris_1-25-1.enc
NEW BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/X4AWD_Yaris_1-25-1.enc
Re: Latest Firmware Releases
Posted: Fri Dec 15, 2023 5:20 am
by Ryan.g
Changes since 1.25.1:
* Added LatG Duty Adjustment
OLD BOARD - Firmware Version 1.27.1 - https://www.syvecs.com/downloads/AWD_Yaris_1-27-1.enc
NEW BOARD - Firmware Version 1.27.1 - https://www.syvecs.com/downloads/X4AWD_Yaris_1-27-1.enc
1.29 Firmware Release
Posted: Mon Apr 15, 2024 3:08 pm
by Ryan.g
Changes since 1.27.1:
* USB Datalogging
* Added Launch Mode
OLD BOARD - Firmware Version 1.29.1 - https://www.syvecs.com/downloads/AWD_Yaris_1-29-1.enc
NEW BOARD - Firmware Version 1.29.1 - https://www.syvecs.com/downloads/X4AWD_Yaris_1-29-1.enc
Posted: Tue Apr 15, 2025 7:12 am
by Ryan.g
Changes since 1.29.1:
* Enable Load for Steering Angle Multiplier
* Option for AN1 to be BurnOut Switch or TransferCase Temp
* Transfer Case Temp Linearization and Limp
Firmware Version 1.34 - https://www.syvecs.com/downloads/X4AWD_Yaris_1-34-2.enc
Posted: Tue Jul 15, 2025 4:58 pm
by Ryan.g
Changes since 1.34.1:
* Added AWD Temp Diag CAN Stream for CANCHECKED Dash
Firmware Version 1.35 - https://www.syvecs.com/downloads/X4AWD_Yaris_1-35-2.enc
