K24 S6GP wiring
Posted: Mon Feb 07, 2022 10:15 am
				Hi all,
I am trying to wire S6Gp to Honda K24 turbo. I am not able to figure out which pin can be used to run Vtec output. I think i should use a relay and use any pull down to supply 12v to switch Vtec on. This has only one Vtec in the intake. No exhaust Vtec.
I can see variable valve timing exhaust A and inlet A assigned to Slave1 Out #01 and #02 respectively in the pin assignments in the basemap that I was supplied. I don't have any expander box. What do these pins refer to?
Mahesh.
Mahesh.
