GDI Injection Angle Tuning
Posted: Thu Oct 06, 2022 5:34 am
				Hello,I am currently tuning a direct injection.
Now I have to adjust the injection angle. What is the best way to proceed?
How do I determine the perfect value? Actually
The perfect value should be where the lambda control regulator goes down, right?
e.g. WOT, Lambda 0.80 with 0% control, as soon as you set the angle 20 degrees later
and the lambda remains value but the regulation goes in -10% is that is the right way?
what tricks do you have to do so for tricks?
Cheers GLDN6
Cheers GLDN6
