Newbie slight issue
Posted: Sat Oct 08, 2022 5:17 pm
				High guys new to the forum.
Im Running Syvecs with toucan on my Focus Rs mk2.
I changed air filter to a Group A which is bigger than the one I had on.
Anyway fitted the Group A and was OK till i reved it a couple of times and then it cut out.
Decided to refit the filter it had on from the start, and noticed on the toucan it seems to be on the pop and bang map, when I try and change maps it cuts out.
On first click before ignition it shows med boost map but on start up it's on pop and bang map.
Any ideas guys? Thinking it might reset when I start from cold hopefully.
