				Latest Base Map
				Posted: Tue Feb 21, 2023 11:57 am
				by Ryan.g
				The latest VAG MQB4 AWD Base map which matches the latest firmware can be found below in Attachments
MQB4 is only available on the X4 Hardware
This base map limits the Max duty to 70%, Some users of the Rs3 Kit from Iroz motorsport have the duty limits at 80% or even 90%. You will need to adjust in Scal to Suit
				1.25
				Posted: Fri Apr 07, 2023 7:01 pm
				by Ryan.g
				Re: Latest Base Map
				Posted: Fri Dec 15, 2023 5:49 am
				by Ryan.g
				Re: Latest Base Map
				Posted: Mon Apr 15, 2024 2:21 pm
				by Ryan.g
				The latest VAG MQB4 AWD Base map which matches the latest firmware 1.28 can be found below in Attachments
				Re: Latest Base Map
				Posted: Fri Apr 19, 2024 1:06 pm
				by Ryan.g
				The latest VAG MQB4 AWD Base map which matches the latest firmware 1.29 can be found below in Attachments
