				Syvecs Tiny dash
				Posted: Fri Sep 01, 2023 11:16 pm
				by motors
				Anyone got experience setting up Syvecs Tiny dash with Syvecs 7. Can access device but receiving no data. Got a few questions . thanks
				Re: Syvecs Tiny dash
				Posted: Mon Sep 04, 2023 1:29 pm
				by Syvecs Ed
				This should be easy. How have you got it set up?
				Posted: Mon Sep 04, 2023 4:20 pm
				by motors
				I have got device powered up loaded the defaults settings. I am able to change colours on screen. I currently have it just powered by USB on pc and not connected to the car. I watched the syvecs video on it and tried changing the ait linerisation to see screen change but no change on screen . I have plugged device into odb port  and receiving no data. Any help welcome
				Posted: Mon Sep 04, 2023 7:37 pm
				Does it even support OBDII data?
				Posted: Tue Sep 05, 2023 6:55 pm
				by motors
				Yes it does , selected default config, selected my car ECT is supported on my car done initial test on odb port and no data. Checked wiring all good. Will connect to ECU CAN once I prove its working. Anyone goy any experience with the TIny dash setup.
				Posted: Wed Sep 20, 2023 1:58 pm
				by Syvecs Ed
				Works fine on my car with ODBII.
But with regards to the S7, should be simple enough your dealer will be able to assist, you use either the S7 slave default stream or program your own on Can2.
				Posted: Mon Jan 15, 2024 6:57 am
				by ervinhaley
				TimH wrote: Mon Sep 04, 2023 7:37 pm
The data is split in Mode, PID and data bytes (A, B, C, D) as below. Identifier: For OBD2 messages,
dinosaur game the identifier is standard 11-bit and used to distinguish between "request messages" (ID 7DF) and "response messages" (ID 7E8 to 7EF).
				Posted: Mon Mar 25, 2024 9:15 am
				by lesary
				To the best of my knowledge, it communicates with the TCM and does not need a complete rewiring of the mechatronics infrastructure. It is possible that this has certain restrictions, but in terms of convenience of use
snow rider 3d, it ought to be simpler and more expedient to get up and running.
