Page 1 of 2
				UK 200sx S14a ECU pinout
				Posted: Mon Feb 08, 2010 8:33 pm
				by DanS
				I've attached a diagram of the ECU pinouts for a UK 200sx S14a SR20DET.
Jez, does this version look correct and match the one you used to make your wiring harness?
Dan
				Re: UK 200sx S14a ECU pinout
				Posted: Wed Feb 10, 2010 11:26 pm
				by Jez
				Looks ok to me - probably worth double checking in the service manual. I used an S14 loom on my engine, so the pin outs are a little different - I've passed on my wiring to Ryan
				Posted: Fri Feb 12, 2010 9:52 pm
				by jezzpalmer
				Jez wrote: I've passed on my wiring to Ryan
But making looms is so therapeutically satisfying...
				Posted: Sat Feb 13, 2010 1:26 pm
				by Jez
				LOL
I actually meant wiring diagram - not the actual wiring
				Posted: Mon Feb 22, 2010 6:46 pm
				by DanS
				Thanks Jez.
Good to see your car breaking the 600bhp barrier on Saturday too:)
				Posted: Sun Feb 28, 2010 1:50 pm
				by Ryan.g
				Nearly finished your Loom Dan
Need to know though abit more abit the ECCS Stuff and how the ecu power is switched on
Also can you get the exact pin descriptions of what each CAS pin does. Ie which is ground, which is signal etc
Ryan
				Posted: Wed Mar 03, 2010 2:27 pm
				by DanS
				Here's a link to the S14a Service Manual supplement
http://media.sxoc.com/contributors/petr ... manual.pdf
Hope it has the right info in there, otherwise I'll try and get the info from the club.
				Posted: Wed Mar 03, 2010 6:49 pm
				by DanS
				Looking at Page EC-23
Pins 31 and 40 are Camshaft position sensor Reference,
Pins 22 and 30 are Camshaft position sensor Position
Page EC-132 onwards has the full list of ECU pin outs....wish I'd seen that first!
				Posted: Sun Mar 21, 2010 10:41 pm
				by DanS
				How's it going Ryan, did you find the info you needed?
Started pulling the old bits out of the car this evening. AVCR, SAFC2, EDFC, Racelogic etc....amazing how much extra wiring I seem to have accumulated over the years. Even found parts of an old carphone kit still tucked behind the dash from years ago! Think I have buyers for all the old bits too which should help towards some more suitable suspension.
Charlie said you use a Mac valve for the boost control, so I'll need to get hold of one of those too, plus a different filter kit to replace the airflow meter and current apexi filter. The intercooler cold pipe will be coming off this week so I can take it to get a boss welded in for the intake sensor
				Posted: Thu Mar 25, 2010 12:21 am
				by Ryan.g
				Hi Dan
Info helped alot and have all the pinouts now im sure
With regards the Mac valve i try to stock these.
Airtemp sensor this will do nicely
http://www.efi-parts.co.uk/index.php?productID=181
Ryan
