Syvecs, Canbus and Dash2.
Posted: Thu May 05, 2011 8:23 pm
				Hi all,
I'm running the S6 on a 3sgte/MR2 and im looking to get a Dash2 soon and feed it via the canbus.
What i'm wondering is what info is available to be fed via the canbus to the dash2?
My plan is to feed 4 EGT signals to the syvecs, one directly and the others via 3 amp's, which output 0-5v linear from 0-1250'c, using some of the spare inputs.
Does anyone know whether i'l then be able to re-name these in the syvecs & dash2 to EGT#1,2,3 & 4?
This a list of things i'm looking to feed into the syvecs and then the dash2,
4 x EGT's,
3 x Map sensors, 2 for Exhaust back pressure and one for manifold,
Oil Pressure,
Fuel pressure,
Oil temp,
Water temp,
Lambda/AFR,
So can someone explain to me if it's possible to re-name the signals and what signals are available via the canbus, or is there a list of whats available?
Many thanks,
Michael.
Edit, the reasons for asking is that i was speaking to someone today that runs a link and dash2 using the canbus and he was unable to re-name any of the inputs etc.
4 x EGT's,
Oil Pressure,
Fuel pressure,
Oil temp,
Water temp,
Lambda/AFR,
Many thanks,
Michael.
