setting up the idle control valve
Posted: Tue Aug 28, 2012 11:04 am
				when im connected to the ecu where will i find the idle control valve option,
i have a evo 8 and it was idling at 2k so i removed the icv and turned ignition on to see if worked, it does work but by doing this i've been told on a evo you have to set the icv via the ecu, now its gone the opposite and wont idle at all just stalls, so i've adjusted the throttle cable to get it to idle.
so need to go into ecu and adjust it, can anyone point me in the right direction in where to go in the ecu to find it?
