				permanent log in not working
				Posted: Sun Sep 28, 2008 10:56 am
				by dynamix
				I keep having to log in on every visit despite being on a static IP address and cookies allowed.
Any way to solve?
				Re: permanent log in not working
				Posted: Sun Sep 28, 2008 8:49 pm
				by JP WR1
				May be they are trying to tell you something! PMSL!
I recognise you from the wr1oc....i am JP on there!
				Posted: Sun Sep 28, 2008 11:17 pm
				by Charlie
				Allow me to switch from dyno/ecu mode into tech support
You should be able to remain logged in. I would delete all your cookies etc and try logging in again checking the 'remain logged in' box once more.
I shall meander off and check your settings just to be sure.
What browser are you using?
Charlie.
				Posted: Mon Sep 29, 2008 7:47 am
				by dynamix
				Firefox 3.0.3
Cheers Charlie
It's no biggie if you can't sort it but it is nice to look in every day to see the latest incarnations and installations for when I finally get mine in the car.
				Posted: Thu Jan 28, 2010 5:37 am
				by bdog
				I'm experiencing the same problem after the domain name change. I guess phpBB tries to set cookies with the old name.
				Posted: Sat Jan 30, 2010 12:54 am
				by pat
				Should be fixed
All solaris-ecs traffic is HTTP 301 "Permanently Moved" over to syvecs.com, so cookies now set to syvecs.com. If you log in using syvecs.co.uk the board will still work but it may not remember your details... would therefore suggest using syvecs.com.
