				tacho output
				Posted: Sun Mar 09, 2014 11:18 pm
				by ford racing
				hi i need advice on setting up tach output .out put is assigned to pin 4(ignition 6) what other settings have to be configured to get an output ,thanks in advance steve
				Re: tacho output
				Posted: Mon Mar 10, 2014 9:25 am
				by C. Ludwig
				You'll most likely need a pull-up resistor installed.  Usually to 12V.  I've used a 1k ohm resistor to 12V on several cars with good results.  Other than that, you just set the number of pulses in the software.  Change the pulses until the reading matches actual RPM.
				Re: tacho output
				Posted: Thu Mar 13, 2014 9:20 pm
				by ford racing
				thanks for reply can you clarify exactly where resistor has to go .
				Re: tacho output
				Posted: Fri Mar 14, 2014 9:59 am
				by C. Ludwig
				Re: tacho output
				Posted: Fri Mar 14, 2014 4:40 pm
				by ford racing
				cheers will give it a go at the weekend
				Re: tacho output
				Posted: Thu Mar 20, 2014 4:15 pm
				by ford racing
				thanks have now got tacho
