Possible additions to the software
Posted: Wed Oct 29, 2008 12:50 am
				Hiya Guys,
Just had a couple of thoughts on what would be some nice additions to the software and wasnt sure where to post them.
* launch control
- overall enable has 3 options, disabled, launch switch, pit limit switch, could another option be added for just enabled, this would mean launch control was always on and the strategy config would dictate when its active, this means we wouldnt need to wire in a switch and lose an input for it. You could for example say its on below 7mph.
* sensors
- would it be possible to add a sensor setup for diff fluid temp for logging purposes
* water injection
- currently WI only uses output functions, would it be possible to have an input (0-5v) that could monitor flow and the turn off WI if there is an issue. To extend this further you could utilise a different fuel and ignition map when WI is on to take advantage of the extra cooling and meths.
*egt
-have an egt protection strategy so that the ecu can alter fuel or ignition timing when egt reaches a configurable set of thresholds.
What do you think?
* launch control
* sensors
* water injection
*egt
What do you think?
