Shiftlight module
Shiftlight module
Available immediately from our shop (http://www.jti.uk.com), I'm pleased to announce the launch of our long-awaited shiftlight module.
This compact unit has 8 high brightness full-colour LEDs that can be configured directly from a Toucan unit or by using a PC programme (from the website), it can work directly from the CAN datastream of a Syvecs ECU (or any other ECU that has RPM data available via CANbus).
The unit is the same width and depth as a Toucan (it's 100x20x16mm and weighs just 30g) and comes with a 60cm lead that allows it to be plugged directly in to the back of a Toucan, or one end can be cut off and then the unit direct wired to the ECU.
Normal price £225+VAT but until the end of November 2014 there is an introductory offer of just £200+VAT. USB programming cable is an extra £25+VAT.
