Wiring ABS sensors for traction control
Posted: Sat Jan 24, 2015 12:53 pm
				HI all,
Need some help wiring in the ABS sensors on a Toyota Supra. With help from Ryan I understand what I need to connect but working through this I found a possible problem.
As far as I understand , I need to connect the front left and rear left abs sensors to AB3 AND AB4 respectively. If I want to use all four ABS sensors I need two signal converters and connect these to AU1 and AU2.
Problem I have is that there is not a pin 38 in the syvecs loom adapter, and as far as I can see, has not been brought out to the 12 way expansion connector.
