MAP Sensor readings
Posted: Thu Sep 10, 2015 9:36 pm
				What sort of values should I be seeing with the engine not running and with engine at idle with a 4 bar sensor - thanks
			Atmospheric should be around 1000mbar, give or take.Arch wrote:What sort of values should I be seeing with the engine not running and with engine at idle with a 4 bar sensor - thanks
