				MR2 Tacho Not Working
				Posted: Wed Dec 23, 2015 8:35 am
				by peterguk
				I have seen a couple of threads on this with lots of suggestions and discussion, but no definitive answer.
I have an MR2 with 1ZZ COPs.  All up and running except for tacho.
Does anyone have a proven, known solution?
Pull up resistor on PWM output?  If so, value?
				Re: MR2 Tacho Not Working
				Posted: Wed Jan 06, 2016 12:55 am
				by peterguk
				Sorted.
Not sure why i have to get another owner to unwrap his loom for the answer, but hey ho.
Ryan, your voicemail isn't working.  Or you need to change the message so callers don't have any expectation of a callback.
				Posted: Wed Jan 06, 2016 7:17 pm
				by KulinPapa
				And what was the solution?
				Posted: Thu Jan 07, 2016 12:38 am
				by peterguk
				1K pull-up resistor across the output assigned to tacho, and bypass the input resistor on the tacho pcb in the cluster.
Now working perfectly.
				Posted: Thu Jan 07, 2016 11:36 pm
				by KulinPapa
				Thanks a lot! I'll have a toyota project soon. So its good to know
				Posted: Fri Jan 08, 2016 9:00 am
				by Charlie
				Hi Peter,
Sorry your post was missed, Ryan no longer does mapping in the UK as he has moved abroad, which will be why his phone was working.
You should have recieved a reply on here, but sometimes posts get missed,
Regards,
Charlie
