request assistance to the connection of a s6 on skyline r33
For Nissan Technical Chat
Sponsored by www.h-dev.co.uk
krysto_77
Post by krysto_77 »
Hello friends
I introduce myself I'm christophe and I am french I have a skyline r33 gtr prepared with a 2.7L and a gearbox getrag
I bought a syvecs management but I have small problem for some trendy Module
would you have the opportunity to give me the information pourait afford to finish connecting all went device with schemas if was possible for you
here are the devices that still have to connect before startup
the joystick has two cables
the solenoid and the 3-way valve
the flex fuel
I guess the branch are:
GND = earth OK
out =
Vcc =
Out = I guess that was the + after ignition
Vcc = goes to the box on the AU4 / AN08
I also have two devices plx a plug for my AFR and ETG
it is possible to connect is on the case
because I also have a ntk supplied probe during my purchase
here is the only thing I received with the purchase any item
thank you to you if you will help me to finish the connections
once all that will be mounted I would like to come to England to management sva import is expensive or cheap or rb motorsport syvecs
desolated my English and poor so I go through a translator
cordially
christophe
Re: skyline r33 gtr 2.7L with getrag made in France
Hi Christophe, if the Syvecs team dont see this, you might be better to email Syvecs directly.
I believe Romain is French and may be able to help you better, not sure of his direct email though
https://www.facebook.com/Syvecs/posts/715752205119045
Although in English, the user manual for the Syvecs may be some help too
http://www.syvecs.co.uk/support/product ... d-pinouts/
With the Syevcs you do not need the external wideband, as the Syvecs can connect to an NTK Sensor directly, the manual above covers this.
krysto_77
Re: request assistance to the connection of a s6 on skyline r33
Post by krysto_77 »
hi stevieturbo
I met Roman in recent weeks on paris
he already gave me information on the Flex Fuel who helped my well
I think that after a lot of work and that's why I'm going through the forum to try to obtain the necessary information
I'll go through it to manage my gtr because I saw he did on a Honda Civic with E85
I would like to go all this quickly enough to come to England to mapping
I'll print is that you gave me as documentation thank you
Bonjour Christophe,
The "joystick" is a "CAL" switch - white wire to the ECU input, black wire analogue ground.
Solenoid - one wire to ECU output, one wire to +12V. Doesn't matter which way.
Flex Fuel:
VCC = +12V
Out goes to ECU
NTK - connect to ECU direct and EGT connect to ECU direct.
But - if your PLX has a voltage output for these, take wires from the PLX to the ECU which will work OK, but ECU must be set up correctly.
krysto_77
Post by krysto_77 »
thank you very much TimH
with documentation and your information I should get out
saw that was the first time I work on such a big management I lost a can
I'll make a connection diagrams of places when I have finished it will be possible to confirm me if I made things
