Bosch LSU4.9 on S8
HondaDrag
Bosch LSU4.9 on S8
Post by HondaDrag »
Hi guys, can the Bosch LSU4.9 be wired inn and used on the S8.
I usually use the NTK L2H2 but the new Bosch is cheaper and have quite a wide range of operation.
Re: Bosch LSU4.9 on S8
no
Interface is different so not advisable.
if you want to use the LSU, then you could look at the S6GP+, or an S6 with an I/O expander that has the LSU support built in (S8 with expander is probably too expensive).
HondaDrag
Post by HondaDrag »
Thanks guys but are you sure because I have downloaded the S8 wiring/pinouts guide from website and it says that it can be used.
I have sent an email to Ryan to be sure.
On manual it says that solder bridges need to be changed in order to make different sensors to work.
I will let you know when I have an answer.
HondaDrag wrote:Thanks guys but are you sure because I have downloaded the S8 wiring/pinouts guide from website and it says that it can be used.
Post where the wiring/pinout say this ?
HondaDrag
Post by HondaDrag »
http://www.syvecs.co.uk/support/product ... d-pinouts/
Scroll down to ECU Pinouts and wiring guides and download S8 wiring guide and pinouts pdf and see page 14 and 15....
HondaDrag wrote:http://www.syvecs.co.uk/support/product ... d-pinouts/
Indeed it does say that, along with wiring pins etc. It doesnt look like a mistake ?
I know the S6 doesn't support the LSU but it does indeed look like the S8 supports them :)
TimH wrote:I know the S6 doesn't support the LSU but it does indeed look like the S8 supports them :)
Or there's a mistake in the manual.
HondaDrag
Post by HondaDrag »
Ryan confirmed that the LSU 4.9 can be used on the S8 :)
This is his repy
"The Bosch LSU can be used with the S8 but the heater control is not as
good as the S6Plus which means the life span is a little shorter but its
never become an issue for anyone, some clients have been doing this for
years"
Great news as i prefer to use the LSU4.9....faster response, wide range of operation and cheaper to replace especially when used on leaded racing fuels
