				IGN output load capability?
				Posted: Tue Jun 06, 2017 10:39 am
				by C. Ludwig
				The IGN outputs are rated at 20A.  What duty can those be run at consistently when used for aux functions?  I have a couple fluid pumps that should run in the 10A range.  Can they be connected directly to the ECU on an IGN output and run at 100% duty or is a relay advisable?
				Re: IGN output load capability?
				Posted: Tue Jun 06, 2017 11:16 am
				Given the size of some of the wiring pins used on the ecu etc....not sure I'd want to risk a 100% duty load running through them at high current even if the ecu could handle it ? Even if the IGN's do use the larger pins.
Unless it was still short duration run time at that duty ?
You'd also be generating a lot of heat within the ecu by doing so ?
Risk vs reward ?
				Posted: Tue Jun 06, 2017 11:19 pm
				by C. Ludwig
				My gut agrees.  But it never hurts to ask.
