Yaw or Lat G for FWD traction control
Posted: Sat Jun 17, 2017 2:10 pm
				I've been pondering the sensors I'm going to need for my car recently and am looking for some advice on what the best sensor would be for varying the TC slip% on a FWD car?
I know that Yaw is listed as being the recommended sensor, which seems perfect in a RWD application, but I'm not so sure on FWD?
In RWD if you overpower the drive wheels you would generally get increased rotation, hence the use of Yaw, however in a FWD the inverse is generally true, you would reduce rotation rate, so Yaw would then not make sense to me?
With the above in mind I am thinking that Lat G is probably the more useful sensor here?
Thanks in advance for any help
