S6 running with SR20DET
Jez
- Horsham Developments
Just got to sort out the cold start, figure out why I'm not getting a speed reading from my ABS sensors and get some pins from somewhere so I can get my boost control solenoid wired up.
Re: S6 running with SR20DET
Good stuff Jez
Is this in your TA car?
Jez
Yup - should be good
Got the cold start and closed loop lambda control sorted this evening
How did mapping go Jez?
Jez
Not too bad. Some how managed 530bhp at 1.4 bar (got 470bhp on the old ECU, reckon its down to the rings being bedded in after the last track day - the engine has only done around 350 miles) and 549 at 1.6bar. I'm quite det limited, which I think it due to the CR being higher than I'd have liked. But still, 550bhp in a 1100kg car is good fun
You had chance to try it in anger or you waiting for abingdon?Jez wrote:Not too bad. Some how managed 530bhp at 1.4 bar (got 470bhp on the old ECU, reckon its down to the rings being bedded in after the last track day - the engine has only done around 350 miles) and 549 at 1.6bar. I'm quite det limited, which I think it due to the CR being higher than I'd have liked. But still, 550bhp in a 1100kg car is good fun
Jez
Not tried it properly on the road or track yet. I have been for a quick blast though and its chuffing quick.
