NTK manufacture a lot of sensors that the general public don't know about or get to see. The best ones are laboratory grade and last I enquired Horiba had an exclusive on those, ie you cannot buy one from NTK and use it in a lab grade application.... but then considering the price you probably wouldn't want to anyway
 There are some lesser sensors that are available for around UKP 350 plus the VAT, which Horiba did use in their lower end kit, and which you could get from NTK so long as you were not going to use it in a lab-type environment... but there was a requirement to prove that you were using it for "something else", in-car lambda control in motorsport being an acceptable "something else". Then there are the mass produced sensors like the LZA09-E1 which are OEM / pattern part and have no restriction on application, but they are no match for the lab grade ones so Horiba didn't care: if you wanted lab grade measurements then you couldn't do it with an LZA09-E1 anyway so you were back to square one - buy from Horiba.
 There are some lesser sensors that are available for around UKP 350 plus the VAT, which Horiba did use in their lower end kit, and which you could get from NTK so long as you were not going to use it in a lab-type environment... but there was a requirement to prove that you were using it for "something else", in-car lambda control in motorsport being an acceptable "something else". Then there are the mass produced sensors like the LZA09-E1 which are OEM / pattern part and have no restriction on application, but they are no match for the lab grade ones so Horiba didn't care: if you wanted lab grade measurements then you couldn't do it with an LZA09-E1 anyway so you were back to square one - buy from Horiba.The motorsport ones I have looked at / used are different to the L1H1 and L2H2 both in construction and markings. I've not come across them through any of the motor factor type sources. We can supply them, but don't tend to hold stock because we don't get asked for them that frequently (not surprising considering the cost!).
