Hi all
Here is the config pack for the Dash2
In the zip file you have:
Can adaptor flash file
Basic Dash2 config file
Syvecs cal file with Custom can bus data to match can adaptor config - PasteCal all Can stuff into your map
See attached
Ryan
Race Tech Dash2 Config Files Pack HERE
- Syvecs RT Dash2 Package.zip
- (265.92 KiB) Downloaded 3035 times
Re: Race Tech Dash2 Config Files Pack HERE
Found a slight error with the frame content on one of the sensors and now updated within the package above
Ryan
Ryan
Top stuff matey, I was going to call you about these bits and pieces
Hi tried to load your file onto my dash2 but it only gets to 99% then stops and the dash then goes into a fail mode with no back light and only parts of the dash working. You then have to do a dash 2 reflag with the original software to get it back to standard again. Any help available to sort this?
Hi Bart,
This must be an issue with the new Dash2 config software.
I would suggest speaking to Lorne at Race Technologies and send him config file
Ryan
Ryan
Ok many thanks mate will do.
tarmac terror
Has this now been resolved??
TT
TT
Yes Lorne has updated so you can select Syvecs on software now.
Any information on how this interface will work with the new Dash 2 Pro, which is touting a direct 1M CAN interface? Or will we have to sit and wait for the 'comming soon' to be formally elaborated on by RT?
It's easy. The new range of RT stuff is great, and the current software a quantum leap in terms of speed.
The new system means just unlock 15 CAN channels and configure them in the same way as you used to with can->serial adaptor. The Syvecs also outputs direct RT serial stream too.
The Dash 2 Pro is based on the new DL1 processor platform so some of the stuff is taking a little while to get ported over, but it's all coming along nicely, I spoke to Martin at RT a few days ago and they marching on with all that stuff.
