new to all of this
hagar
Re: new to all of this
Post by hagar »
you seem to have missed the entire point of the post. i live on the westernmost tip of wales. it is at least a 4 hour drive to get any tuner here. i have changed my turbos and manifolds which means that every water and oil pipe is a new and untested connection. when i start it up and get it warm i could have a dozen leaks to sort out taking days. what is the engine tuner supposed to do whilst i fix them. i don't need it running down the road but i do need to get it warm to sort out any leaks and see it there are any problems with the dozens of new brakets i have had to make up.
there are loads of things to check long before tuning it as very little is original. it isn't just the computer i have changed. i went mental!
pavlo
Zen Performance
Post by pavlo »
Getting someone out there isn't out of the question, however I agree it's not ideal, especially if you have some other niggles along the way.
So what I would recommend is that you strike up a relationship with a tuner that can talk you through stuff on the phone, do things remotely via your laptop over the net, trouble shoot with you etc. Don't expect all this come for free of course, but it should get you into a position to get the car mobile and then proceed to some running in.
If you have a schedule used for the loom or adaptor, that would allow an experienced tuner to craft a startup map, but you will need to confirm all sensors and outputs are working too.
pavlo
Zen Performance
Post by pavlo »
You getting anywhere with this? Anyone lined up to get you some help?
hagar
Post by hagar »
still doing the wiring, bought loads of stuff and am now paying the price by having to wire it all in to the original looms. will get there in the end, one wire at a time.
stp88
Post by stp88 »
Hi , Pm me and i well get you going :geek:
hagar
Post by hagar »
getting there
underbonnet nearly finished but the inside not even started properly yet. engine/computer loom just chillin' out on the passenger seat.
dash needs finishing as well.
hagar
Post by hagar »
engine running (thanks ryan). missing on 1 cyclinder. suspect fouled plug.
next major problem
windows 7 and this software?
has anyone put this onto a windows 7 laptop and how?
pavlo
Zen Performance
Post by pavlo »
just install the latest version, runs no problem.
However if you let your laptop sleep, when it wakes up it will have dropped the LAN port, so you need to log off and then back on, or restart the machine. The trick is not to let it go into standby when you close the screen, I change the power saving setup on my mapping laptop. If you close the Syvecs software first and manual go into standby it's not a problem.
hagar
Post by hagar »
i thought i had the latest version. do they come with version numbers, if so which version for win 7?
pavlo
Zen Performance
Post by pavlo »
Just download the latest version from the forum. This is something that should be checked for routinely as some firmware upgrades require it. There is no one specific version of the software as each component has it's own version.
And check the power situation, make sure you have done a hard reset of the machine then start the syvecs software to be sure.
