S6 Pnp the same as GP
CT9A
Post by CT9A »
Is a subaru pnp ecu exact the same as a GP? Only the connectors are different to connect to the ecu? Do they have the same amount of inputs and outputs? If so, you can make it work on any other car with a loom adapter?
pavlo
Zen Performance
Re: S6 Pnp the same as GP
Post by pavlo »
It uses the same control board internally. So if you have a PnP from any model, you can buy a new base board for a different PnP application, or you can buy a GP base board and case. However for EVO 4-7 (& 260) you are much better off with a PnP board as it has lots of additional functionality external to the control board.
CT9A
Post by CT9A »
And what about a evo ix? I don't see a pnp listed for the ix.
Evo IX still uses a loom adapter, unless Pat's been quietly busy :)
Current loom adapters have an Aux connector with as much spare I/O brought out as possible, along with a comms connector for CAN and RS232, an EGT connector, and a connector for a PnP-style wideband cable. Much improved on older versions....although I say it myself LOL
